TwinTurbo.NET: Nissan 300ZX forum - Correct. As engine/bay temp rises, so does fan speed.
Multi_Read (MO)
on January 22, 2013 at 4:33 PM
I think it expands and will slip less when hot (n/m)
posted by njz
on January 22, 2013 at 02:57 PM
Only way it can do that is if it gets tighter during a higher temp. When your engine is cold, the fan should spin freely with minimal resistance, if any.
Fan Clutch ?
MrPulldown(Tahoe)
12:50:03 01/22/13
It will always be spinning. (n/m)
Woody75 (Denver)
12:56:43 01/22/13
Re: It will always be spinning.
MrPulldown(Tahoe)
13:14:33 01/22/13
A clutch fan is belt driven and will always spin
white22sky
13:18:24 01/22/13
always spinning
JaffaUK
13:18:59 01/22/13
Thanks. (n/m)
MrPulldown(Tahoe)
14:36:44 01/22/13
njz
14:57:20 01/22/13
Correct. As engine/bay temp rises, so does fan speed. -
Multi_Read (MO)
16:33:33 01/22/13
I had my car on a scope when it failed smog last.
MrPulldown(Tahoe)
15:10:11 01/22/13
your O2 sensors aren't supposed to cycle at idle
aliaZ
15:14:48 01/22/13
I think this is up to debate
MrPulldown(Tahoe)
15:56:26 01/22/13
He knows it does, but running cool will run rich at idle.
TriniTT
16:06:35 01/22/13
I'm trying. Am hoping this new fan clutch does it.
MrPulldown(Tahoe)
16:29:46 01/22/13
Thermostat. (n/m)
TriniTT
17:11:04 01/22/13
^^^ Thermostat (n/m)
njz
18:13:09 01/22/13
The FSM says to rev to around 2000 RPM to test the O2
aliaZ
17:28:29 01/22/13
My thermostat was replaced 15k ago.
MrPulldown(Tahoe)
18:13:58 01/22/13
what part of the emissions test did you fail?
aliaZ
18:48:28 01/22/13
Co (n/m)
MrPulldown(Tahoe)
11:14:53 01/23/13
Re: My thermostat was replaced 15k ago.
hmb
18:48:33 01/22/13
My AIV is fully functional. (n/m)
MrPulldown(Tahoe)
11:15:36 01/23/13
I passed w/o AIVs several times
BlackholeZ
13:14:18 01/23/13
Passed with a stock ECU, or an upgraded ECU? (n/m)
hmb
13:46:25 01/23/13
Both - AIV only effects cold start idle (n/m)
14:15:02 01/23/13
Stock NA, Ash TT (n/m)
BlackholeZ
02:50:33 01/24/13
They spin and they spin and they spin and they spinnin! (n/m)
boileralum
14:18:00 01/23/13
